Hello, I have a problem with the ovh api, I would like to integrate in our CRM the possibility of renewing domains directly using the API, following the guides I am trying this script to renew the service linked to a domain but I receive an error.
{"message":"[services] ServiceId Data is not an array for an array type"}
require DIR . '/vendor/autoload.php';
use \Ovh\Api;
$ovh = new Api( $applicationKey,
$applicationSecret,
$endpoint,
$consumer_key);
//$result = $ovh->get('/service/14991863/renew', array(
// 'includeOptions' => false, // Include service's option(s) (type: boolean)
try {
$result = $ovh->post('/service/14991863/renew', array(
'dryRun' => false, // Indicates if renew order is generated (type: boolean)
'duration' => 'P1Y', // Renew duration (type: string)
'services' => '[14991863]', // List of services to renew (type: long)
} catch (GuzzleHttp\Exception\ClientException $e) {
$response = $e->getResponse();
$responseBodyAsString = $response->getBody()->getContents();
echo $responseBodyAsString;
