Problem with sending messages to 'Data Log Platform' from location outside of OVH netwo
When trying to send logs from outside of OVH network to discover.logs.ovh.com:12202 i'm ending up with a response timeout, same request sent from internal OVH network works good.
Do you have some firewall rules in place that block request outside of you network and/or France?
We're based in Poland
Hello Pierre,
Thank you for you quick response.
I also can connect to the server but than after some time I'm getting connection time out.
See below if I use check http it results with connection time out.
I tried both http (2202) and https (12202) endpoints for gelf but it didn't work for me
https://1host.net/check-http?host=discover.logs.ovh.com:2202host.net/check-http?host=discover.logs.ovh.com:2202
On the other hand it always worked form my two ovh vps servers, this is why I thought it might be firewall issue. Do you have any other thoughts what can be wrong here?
Regards,
Hello Pierre,
Thank you, after you last message realized that I used http logger which caused that issue, after changing library everything seems to work correctly.
