Weird directory tree issue in FileZilla
Hello,
I have been using Filezilla for a long time to manage my website under Joomla.
I would like your opinion on this directory structure with folders r/a/n.
My site is in www.
What is this point? On the randogue folder, when I open it, it redirects me to www.
Thanks for your input
Hello,
It's normal (but only the SFTP server shows it like that)
To avoid placing too many client directories at the same level (too many sub‑directories in a single directory, which is bad on both Linux and Windows), OVH decided to create four sub‑levels using each of the first three letters of your login, followed by the login itself.
Thus, it statistically reduces the number of directories at the end of /r/a/n/ by a factor of 26³.
Note that you do not have access to the levels above /r/a/n/randogue.
Hello,
Thank you for the reply
Okay, I understand that it's normal; I had never noticed this... maybe I simply hadn't created those directories.
In any case I can't delete those r/a/n folders, so I'll leave them as they are, perhaps set a more restrictive chmod permission..
