Synchronization problem with Thunderbird
hi
I've had an issue with my Thunderbird client for a long time.
Sent messages and the Trash are not syncing with the web version.
In other words, when I send a message or delete it from Thunderbird, the Sent folder (or the Trash) is not reflected on the web.
and vice versa
If someone can help me because it's annoying
Regards
Hello @Bdovergne
If you’re using IMAP, the Sent folders in Thunderbird and the web applications aren’t the same.
So if you delete it in Thunderbird it won’t necessarily be deleted in the web applications.
Hello,
What Gaston says above is not correct.
Webmail and Thunderbird can perfectly use the same folders for “Sent” and “Trash”.
In each of the two programs, make sure to “subscribe” to all folders to see them all, then decide how to configure the identical folder from both platforms.
Note that if Outlook was involved, it will certainly have created a whole slew of folders in French on the server, and that is a nuisance.
I agree with what @fritz2cat said; it has happened to me as well that sometimes Thunderbird hasn’t subscribed to all folders, confused by the switch from Outlook.
To check whether you’ve subscribed to all folders, right‑click the account in the left‑hand list and then select the “Subscribe…” (Sottoscrivi…) entry. Once the subscription window opens, click the “Refresh” (Aggiorna) button and make sure all folders are checked.
If that still doesn’t work, go to “Account Settings” (Impostazioni account) in Thunderbird’s main menu and, under the “Folders & Copies” (Cartelle e copie) section of your account, ensure that the folder associated with Sent Mail is the correct one. If you have more than one, try a few alternatives.
Side note: The “Subscribe…” (Sottoscrivi…) entry does not appear if you right‑click while the “Unified Folders” (Cartelle unificate) view is active. If that’s the case, switch to the classic view before proceeding.
hi
thanks for your feedback
my Thunderbird version has been installed for a very long time
I now have the impression that it’s a misaddressing of the links.
Indeed, for example, one of the sent folders points to imap …/sent and the other to imap …/inbox/sent
Whereas the messages I send from Thunderbird go into imap …/sent and the ones sent from the OVH web client go into imap …/inbox/sent
Who is right and how can I align the two?
Select one of the two (identical) folders on both of your platforms; this will resolve the issue for any future messages that are sent.
Thunderbird is especially flexible, even when you have multiple mailboxes to manage:
