Server randomly reboots! HELP ME
We took a new server with a powerful enough configuration! From the very start, constant server reboots! The logs are empty! What to do? Help me please!
i create support ticket: 1220995, 1218776, 1220028, 1221103!
last reboot:
reboot system boot 4.19.0-12-amd64 Sun Dec 6 00:38 still running
reboot system boot 4.19.0-12-amd64 Sun Dec 6 00:15 still running
reboot system boot 4.19.0-12-amd64 Sat Dec 5 21:13 still running
reboot system boot 4.19.0-12-amd64 Sat Dec 5 05:55 still running
reboot system boot 4.19.0-12-amd64 Sat Dec 5 03:27 still running
reboot system boot 4.19.0-12-amd64 Sat Dec 5 02:48 still running
reboot system boot 4.19.0-12-amd64 Sat Dec 5 02:06 still running
reboot system boot 4.19.0-12-amd64 Sat Dec 5 01:45 still running
reboot system boot 4.19.0-12-amd64 Sat Dec 5 01:06 still running
reboot system boot 4.19.0-12-amd64 Fri Dec 4 23:02 still running
reboot system boot 4.19.0-12-amd64 Fri Dec 4 22:23 still running
reboot system boot 4.19.0-12-amd64 Fri Dec 4 22:13 - 22:19 (00:05)
reboot system boot 4.19.0-12-amd64 Fri Dec 4 21:13 - 22:19 (01:05)
reboot system boot 4.19.0-12-amd64 Fri Dec 4 20:31 - 22:19 (01:47)
reboot system boot 4.19.0-12-amd64 Fri Dec 4 15:27 - 22:19 (06:51)
reboot system boot 4.19.0-12-amd64 Fri Dec 4 15:07 - 15:24 (00:16)
reboot system boot 4.19.0-12-amd64 Fri Dec 4 14:57 - 15:24 (00:26)
reboot system boot 4.19.0-12-amd64 Fri Dec 4 13:43 - 15:24 (01:41)
reboot system boot 4.19.0-12-amd64 Fri Dec 4 13:30 - 15:24 (01:53)
reboot system boot 4.19.0-12-amd64 Fri Dec 4 11:57 - 13:26 (01:29)
reboot system boot 4.19.0-12-cloud- Thu Dec 3 04:02 - 04:03 (00:00)
wtmp begins Thu Dec 3 04:02:11 2020
Hi @AlexandrS1
Were you able to solve the problem or does it continue? Have you already performed a hardware diagnosis using rescue mode?
Has OVH told you something about what is happening to you?
Please let me know to help you
Greetings,
