Site inaccessible during the day but reachable at night for a few days
Hello, the website and blog on the domain site2wouf.fr are inaccessible during the day, and I receive an evening repair notification but it happens again the next day. Cluster 110. filer 681. Could you be so kind as to tell me more? Thank you in advance.
Hi @wouf
I just checked your domain and see that it is working correctly. It may have occurred at a specific moment. If you encounter the same situation, you can visit the following page to check the service status:
https://web-cloud.status-ovhcloud.com/
Kind regards,
Sergio Turpín
Hello @wouf
http://site2wouf.fr/ works fine on 4G on my mobile phone.
The fact that the site is working at the time of the test doesn't necessarily mean the problem is fixed, especially if it recurs every day.
Next time it happens, try noting the exact time and the displayed error message. A 503, a timeout, or a DNS error would not point us to the same cause at all.
I would also check using a 4G connection, just to rule out a local network issue.
And since you apparently receive a restoration notification each evening, it would be worth asking OVH whether these interruptions correspond to incidents on cluster 110 or filer 681.
Have you noticed if the outages occur at roughly the same times?
Hello @wouf
Switch to Development environment to see the cause of the error
See in my guide the paragraph: P2 - Error 500 - Development Environment
I recently moved my website from a private hosting provider to OVHcloud. However, I started experiencing the same issue where my website would occasionally become inaccessible in different countries including my own country, Slovenia.
I switched back to my previous hosting provider, and my website https://www.labgasflow.com/ started working smoothly again.
I'm trying to figure out whether I did something wrong during the migration or if OVHcloud experienced any server-related issues last week.
I'm still a beginner and don't have much experience with OVHcloud, so I'd really appreciate any advice or suggestions from someone who has dealt with similar issues.
Hello @adinikama
Are you based in China?
Hi @adinikama
Do you remember the error that your site was showing you?
Regards,
Sergio Turpín
